how to ftp connect with PHP ftp connection through script code
Post Description: how to ftp connect with PHP ftp connection through script code
Tags: how, to, ftp, connect, with, PHP, ftp, connection, through, script, code
This Post Was Posted On Feb 29, 2008 By web hosting #1340
how to ftp connect with PHP ftp connection through script code by web hosting
$ftp_server = "localhost";
$ftp_user_name = "tuiz2";
$ftp_user_pass = "@bn0rmal";
$dir = '/web/hello/';
// set up basic connection
$conn_id = ftp_connect($ftp_server);
// login with username and password
$login_result = ftp_login($conn_id, $ftp_user_name, $ftp_user_pass);
// check connection
if ((!$conn_id) || (!$login_result)) {
echo "FTP connection has failed!";
echo "Attempted to connect to $ftp_server for user $ftp_user_name";
exit;
} else {
echo "Connected to $ftp_server, for user $ftp_user_name";
ftp_mkdir($conn_id, $dir);
// close the FTP stream
ftp_close($conn_id);
// check connection
exit;
} else {
this will help in situations where you need to create a directory in your root web directory
©2011 Webune Forums - Sun Dec 18, 2011 3:58 pm
