cut Linux Shell Command - Divide a file into several parts
Post Description: cut Linux Shell Command - Divide a file into several parts
Tags: cut, Linux, Shell, Command, -, Divide, a, file, into, several, parts
This Post Was Posted On Feb 29, 2008 By webmaster #1929
cut Linux Shell Command - Divide a file into several parts by webmaster
Code:
cut
yuckk
#2148 1
i want the instructions, just tell me where i can send them to you
Nov 18, 2008 Reply Report abuse
jessi
#2147 2
i am interested in knowing. i got the text file with the instructions but i cant open it
cody
#2146 3
defenetly very helpful if i new how to use the command
sometime i do have a way of dividing a file into two parts but i have to use linux. i did it once on an hp machine which was running unix and this command helped me get the results i needed.
anwyays, i sent you the howto so you can practice
©2011 Webune Forums - Tue Dec 20, 2011 10:07 am
